Noise floor level of the KMZ60?
simongodfrind
What is the noise floor level of the KMZ60 ?
Between the angle inaccuracy of +-0.1° and the Vn(o)RMS which predominates?
In other words, how many bits (or even better SINAD) I need for the ADC I will connect to it if I want to maximize the precision.
I also would be interrested by the "KMZ60 hand-driven demo board" description. The "KMZ60 application note" only found on google talk a little bit about it.
Thank you,
Tags (2)
TomasVaverka
Hello Simon,
Thank you for your interest in the KMZ60.
I am asking our device group to comment on this. Meanwhile, could you please answer some questions about your end product and application:
1. What is your end product and the application?
2. When is your targeted production date or time frame?
3. What is your projected volume/quantity?
You can send me a direct message or create a standard ticket if you want to keep this information confidential.
Tomas
