Fill unused flash memory on MPC5604B
jean-christoph7
I'm using Codewarrior 10.6 for MCU, and I want to know if it is possible to force codewarrior to fill the unused flash memory with a defined value, because actually the unused flash memory is fill with 0xFF and I need to change it.
Have you an example?
Thanks.
jean-christoph7
Perfect.
Thanks a lot.
martin_kovar
look at the app note in the attachment. In section 5, there is the description, how to fill unused flash memory with predefined pattern.
Martin
jean-christoph7
Perfect.
Thanks a lot.
