Where is the inferface to install a license in CodeWarrior 10.6.4?
donoldham
  I uninstalled and reinstalled the latest CodeWarrior from the NXP site, now under Help there is no License selection.  I registered a node locked license for basic version.
TomasPaez
You need to get your license file from nxp.com
1.     Log in
2.      Go to SW Licensing & Support
3.     Look for your CW Version
4.     Generate the license.dat / certificate assigning your host ID
5.      Copy the file in the app location,
Check this video with more information, hope this help
How to access software products and licenses|NXP
TomasPaez
1.     Log in
TomasPaez
License.dat file needs to be loaded in the following directory
C:\Freescale\CW MCU v10.6\MCU
I see you have an evaluation entitlement that expired on 06/03/2016
Do you need to extend this ?
regards
donoldham
I updated Code Warrior to the latest offline download. Under the Help menu, I do not see the Freescale Licenses. Does it supposed to be there?
Don
donoldham
I do not need to extend as of now. I purchased a basic license from digikey.
Don
