在imx6q的dts文件中修改有线网驱动时
添加fec
&fec {
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_enet>;
phy-mode = "rgmii";
phy-reset-gpios = <&gpio1 25 0>;
fsl,magic-packet;
status = "okay";
有线网络没有成功,但是pfuze是正常的,reboot命令不能重启,只能关闭系统
把i2c2的
MX6QDL_PAD_EIM_EB2__I2C2_SCL 0x4001b8b1
MX6QDL_PAD_EIM_D16__I2C2_SDA 0x4001b8b1
改成
MX6QDL_PAD_KEY_COL3__I2C2_SCL 0x4001b8b1
MX6QDL_PAD_KEY_ROW3__I2C2_SDA 0x4001b8b1
有线网络能成功连接,pfuze如下图错误,reboot命令能正常重启
so, how you connect the ethernet and pmic? The IOMUX setting should match with your hardware design.
