Hexiwear Docking Station
majidrehman
I am facing problem with Hexiwear Docking Station.
When I connect Docking Station with my PC, then always mass drive label shows "MAINTENANCE".
can anyone help me how to fix this problem.
Majid
BlackNight
Hi Majid,
this means that you are in 'bootloader' mode (see https://mcuoneclipse.com/2016/07/12/hexiwear-teardown-of-the-hackable-do-anything-device/ ). This happens if you power on the docking station with the reset button pressed. Or for some reasons you have erased the DAPlink debug application?
- try the docking station without the Hexiwear
- make sure that the reset button(s) on the board are not pressed
- check the voltage level of the reset line, maybe you have a shortcut on your board
- Check the switches (see https://mcuoneclipse.files.wordpress.com/2016/07/cardboard.jpg )
In any case, you can use the onboard SWD cable to debug the Hexiwear.
I hope this helps,
Erich
majidrehman
actually when I connect docking station without Hexiwear then nothing happen meaning mass drive DAPLINK does not appears,
and when I connect Hexiwear with docking station and turn ON, then mass drive MAINTENANCE appears with following files,
DETAILS.txt and HELP_FAQ.htm
any suggestion ?
Majid
