I am looking for Pressure sensor for Gauge Pressure(Not Absolute Pressure!) up to 115KP (1Bar) for measuring water pressure with pipe connector. Please suggest sensor which gives Analog output in voltage range, directly usable by Micro controller Analog Input.
All I am able to find are absolute pressure sensors or differential sensors.
Hi Mahesh,
Thanks for your interest in our pressure sensors.
I would recommend considering either the MPX5100GP or MPXV5100GP/MPXV5100GC6(7)U integrated analog pressure sensors with temperature compensation, calibration and amplifier circuitry on–chip. The output voltage for full rated pressure (100kPa) is typically 4.7V.
Tomas
PS: If my answer helps to solve your question, please mark it as "Correct". Thank you.
