I have seen in the MPC5748G reference manual that the controller support 12 or 16 lines MDO Nexus connection but I could not find either there or in the datasheet if it allows the DDR configuration.
I am planing to use the LA-7630 adapter that supports DDR but I do not know if the processor supports it.
Best regards and thank you very much,
Manuel
Hello Manual,
MPC5748G supports SDR NEXUS trace only.
Maybe other tools like this Microcontroller Trace Support with Universal Debug Engine can help you here.
DDR mode is not supported on this device.
Lukas
Thank you for your response.
