Tried
http://download.eclipse.org/releases/indigo
and
http://download.eclipse.org/releases/juno
and
http://download.eclipse.org/releases/keplar
Get message:
An error occurred while collecting items to be installed
session context was:(profile=PlatformProfile, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
No repository found containing: binary,com.freescale.dsc.PEx.examples_root,1.0.0
No repository found containing: binary,com.freescale.dsc.PEx_root,1.0.3
No repository found containing: binary,com.freescale.dsc.architecture_root,1.0.5
No repository found containing: binary,com.freescale.dsc.buildtools_root,1.0.4
No repository found containing: binary,com.freescale.mqx.common_root,1.1.15.201408201355
No repository found containing: binary,com.freescale.mqx.v4.0_root,1.4.1.201401301129
No repository found containing: binary,com.freescale.mqx.v4.1_root,1.4.1.201408201355
Hi.
if you want to install eGit in CodeWarrior, your can refer article from Erich:
https://mcuoneclipse.com/2013/08/13/installing-egit-in-eclipse-and-codewarrior-for-mcu10-4/
Jennie Zhang
Thanks for the reply.
Unfortunately, this does not work. Error message is
OK, got it to work. Here's what I did.
1. Install CW using the default path: C:\Freescale..., not c:\Program Files\freescale...
2. Install the DSC Support updates using Help > Install New Software. This seems to get the missing files that eGit install was complaining about.
3. Then the instructions in
will work. Use the juno version.
Bert
Thanks for the sharing.
the Git update works normal from my side.
yes, on my side I already have DSC update installed and CW is in folder C:\Freescale\CW MCU v10.6.4
Jennie Zhang
