How to change GPIO out lo to out hi in dts file ?
Question asked by Bandaru Lavanya on Jul 13, 2016
Latest reply on Jul 28, 2016 by Bandaru Lavanya
Hi All,
I am trying wl12xx wifi enable in dts files
wlan_en_reg: fixedregulator {
               compatible = "regulator-fixed";
               regulator-min-microvolt = <1800000>;
               regulator-max-microvolt = <1800000>;
               regulator-name = "wlan_enable_regulator";
               gpios = <&gpio1 15 0>;      //active high
               startup-delay-us = <70000>;
               enable-active-high;
&usdhc1 {
        pinctrl-names = "default";
        pinctrl-0 = <&pinctrl_usdhc1>;
        bus-width = <4>;
        always_present;
        cd-permanent;
        cap-power-off-card;
        status = "okay";
        vmmc-supply = <&wlan_en_reg>;
        non-removable;    /* non-removable is not a variable, the fact it is */
                         /* listed is all that is used by driver  */
        enable-sdio-wakeup;
        status = "okay";
        #address-cells = <1>;
        #size-cells = <0>;
        wlcore: wlcore@0 {
               compatible = "ti,wl1271";
               interrupt-parent = <&gpio1>;
               interrupts = <14 IRQ_TYPE_LEVEL_HIGH>;
               clocks = <&refclock>;
               clock-names = "refclock";
                refclock: refclock {
                        compatible = "ti,wilink-clock";
                        #clock-cells = <0>;
                        clock-frequency = <38400000>;
  pinctrl_usdhc1: usdhc1grp {
                        fsl,pins = <
                                MX6QDL_PAD_SD1_CMD__SD1_CMD             0x17059
                                MX6QDL_PAD_SD1_CLK__SD1_CLK             0x10059
                                MX6QDL_PAD_SD1_DAT0__SD1_DATA0          0x17059
                                MX6QDL_PAD_SD1_DAT1__SD1_DATA1          0x17059
                                MX6QDL_PAD_SD1_DAT2__SD1_DATA2          0x17059
                                MX6QDL_PAD_SD1_DAT3__SD1_DATA3          0x17059
                                MX6QDL_PAD_SD2_DAT0__GPIO1_IO15         0x80000000
                                MX6QDL_PAD_SD2_DAT1__GPIO1_IO14         0x80000000
In this case i got
gpio-15  (wlan_enable_regulato) out lo
in cat /sys/kernel/debug/gpio
After changing
in to
gpios = <&gpio1 15 1>//active high
also i am getting same as above in sysfs entries but i want out hi instead of out lo  how can i get it .
i am using wifi_r8.6 compat wireless.
And
here   vmmc-supply = <&wlan_en_reg>; is for io or for wifi module.
i have 2 power supplies 1) 3.3v for wifi module and 2) 1.8 for i/o lines hopw can i configure those two things in sdhc1.
what is vmmc-supply and vqmmc-supply in sdhc or mmc dts properties, if any one knows kindly help me i am new to the dts files.
Thanks & Regards,
Lavanya
