Hi everyone
i want add the remove function and i get this error, (attached image).
could you helpme?
because i get that error?
regards
tank you
Hello Miguel,
Could share a little more information about your project? Which MXQ version, device, IDE are you using?
Is this an example code?
Soledad
Hi Miguel:
From your attached image, it seems that you need a declaration for your remove function in your header file.
uint32_t my_remove( const char * pathname);
