Latest bsp from YOCTO
joevince
When i am trying to buils the latest version for yocto for imx6q it shows some error there is any additional package i need to install to build the kernel properly!!!! before that i used older on 3.10.17
Labels (2)
joevince
yes i did all and additionally i added a patch for smarc-samx6i !:smileyinfo:
Yuri
  Please try to build the recent kernel, using clean installation
in separate directory. Please follow exactly recommendations
of (recent) "Freescale_Yocto_Project_User's_Guide.pdf".
Yuri
joevince
I am having this guide i can sucessfully build kernel for 3.10.17 when i am trying new none in below repo
repo init -u https://github.com/Freescale/fsl-community-bsp-platform -b krogoth
it gives an error of
/yocto_latest/build/tmp/work-shared/smarc-samx6i/kernel-source/include/linux/compiler-gcc.h:103:30: fatal error: linux/compiler-gcc5.h: No such file or directory | compilation terminated.
Yuri
Do You use the following  ?
$: mkdir fsl-community-bsp
$: cd fsl-community-bsp
$: repo init -u https://github.com/Freescale/fsl-community-bsp-platform -b krogoth
$: repo sync
$: source ./setup-environment build
$: bitbake core-image-minimal
Yuri.
