setting BD rate upper than 115200 for uart in lpc812
Question asked by Mahmoud Hosseini on Jul 12, 2016
Latest reply on Jul 14, 2016 by Rolf Meeser
I'm using below LPCOPEN based codes for configging UART on my LPC812.
for normal baud rate below 115200(most usual) it works fine,but when i set a custom baud rate like(115200 *2) or
(115200 *n) it does not work either.whats problem?
  //---UART Initialing---------------------------------
Chip_Clock_EnablePeriphClock(SYSCTL_CLOCK_SWM);
/* Divided by 1 */
Chip_Clock_SetUARTClockDiv(1);
/* Connect the U0_TXD_O and U0_RXD_I signals to port pins(P0.4, P0.0) */
Chip_SWM_DisableFixedPin(4);
Chip_SWM_MovablePinAssign(SWM_U1_TXD_O, 4);
Chip_SWM_MovablePinAssign(SWM_U1_RXD_I, 0);
/* Disable the clock to the Switch Matrix to save power */
//Chip_Clock_DisablePeriphClock(SYSCTL_CLOCK_SWM);
Chip_UART_Init(LPC_USART1);
Chip_UART_ConfigData(LPC_USART1, UART_CFG_DATALEN_8 | UART_CFG_PARITY_NONE | UART_CFG_STOPLEN_1);
Chip_Clock_SetUSARTNBaseClockRate((115200 * 16), true);
Chip_UART_SetBaud(LPC_USART1, 115200);
Chip_UART_Enable(LPC_USART1);
Chip_UART_TXEnable(LPC_USART1);
