enable serial driver
santhosha
how to enable/disable the serial driver in the imx6 bsp?  And also how to configure the baud rate etc in this bsp.
I am trying to get a minimum bsp that provides a serial console output on which I can enter commands to check the system.
I am using a custom board and not the evaluation board of imx6 solo.
Please guide.
jimmychan
One more information for you, please download the BSP document from here:
i.MX 6 Series Software and Development Tool|NXP
You can find all the driver information from the i.MX_Linux_Reference_Manual.pdf
aravinthkumarja
Senior Contributor II
Hi santhosha​,
In imx6 bsp you can check available serial ports by using below command,
=> ls /dev/tty*
Below command for configure baudrate,
=> stty -F /dev/ttymxc1 115200
Note: for example i given "ttymxc1" you can this port name, with respect to your needed serial port.
Aravinth
