LPCXpresso - Difference between "Program Flash" and "Debug"
Question asked by Vincent Vuarnoz on Jul 11, 2016
Latest reply on Jul 11, 2016 by LPCX support
What is the difference between using the "Program Flash" facility and using the "Debug" facility in LPCXpresso?
What exactly is loaded to the target's flash memory when using debug (Debug and Release)?
The reason behind the question is that "Program Flash" fails because my hardware setup only allows a Wire speed of 300KHz. And changing the wire speed in the Redlink options did not help... So any suggestions on that one would be very helpful too!
Kind Regards
Vincent V.
