Uploading program to FRDM-K82f using command line or drag drop
Question asked by Lalit Kumar on Jul 9, 2016
Latest reply on Jul 9, 2016 by Lalit Kumar
I'm trying to upload demo apps on my FRDM-K82f board. The default bootloader was of mbed, in which I was able to drag and drop the files to program. After that I uploaded OpenSDA bootloader v2.1 on the board. I've followed the steps mentioned in user guide and can successfully run demo apps using GDBServer method. But when I try to drag and drop files now, the board doesn't program.
Also is there any utility to program the board using command line or if you can mention the commands that can be used for programming through JLinkExe that'd be great. I am using SDK with GCC on Linux.
Thanks in advance for help
