Hello support:
I am tring to implement an application on dealing with multiple i2c master in MQX,
For example, when I open one device handle
file_handle = fopen ("i2c1:", NLL);
Then the other device tries to open the same port successfully.
Does MQX driver supports it ?
Solved! Go to Solution.
Hi Andy:
Current MQX I2C driver was not developed/tested for i2c multi master environment. That needs a completely re-design the mqx i2c driver to arbitrate multiple masters that make use of the same bus.
Hi Andy:
