menuconfig
menuconfig
santhosha
How to get the menuconfig to enable/disable the required drivers?
Will bitbake linux-imx -c menuconfig helps?
aravinthkumarja
Senior Contributor II
Hi santhosha​,
Run the menuconfig command:
=> bitbake linux-yocto -c menuconfig
For your Reference:
Yocto Project Linux Kernel Development Manual
gusarambula
Thanks, Aravinthkumar Jayaprakasam!
I would also recommend looking at the following Yocto Tutorial where the kernel is configured outside of bitbake, which is useful in some circunstances.
Yocto Training - Task #5
You may need to use a different kernel recipe depending on which Release of the BSP or Branch from the FSL Community BSP you are using.
