I've installed Codewarrior DSC56800E v8.3 on a Win7 system. When I try to connect to an MC56F8006 using a P&E Micro Multilink Universal, I get an error message: CSSPROTOCOLPLUGIN : CCS : Command Converter not present. How do I solve this issue?
Solved! Go to Solution.
Hello Peter
CodeWarrior v8.3 does not support P&E Micro Multilink Universal. On Win 7 system, it only supports USBTAP:
To debug with P&E Micro Multilink Universal, please choose Eclipse CodeWarrior v10.6.4:
CodeWarrior for Microcontrollers-Eclipse IDE|NXP
Best Regards
Fiona Kuang
TIC - Technical Information Center
Note: If this post answers your question, please click the Mark Correct button. Thank you!
Hello Peter
Best Regards
Fiona Kuang
