elftosb: string parameter
Question asked by Peter Ruesch on Jul 7, 2016
Latest reply on Jul 11, 2016 by Peter Ruesch
I'm having trouble to set a string constant via a command line argument.
I want to specify the firmware binary file as a parameter when calling elftosb.
invocation elftosb:
[developer@localhost linux]$ ./elftosb --debug --command command_file.bd --output output.sb -DAPPLICATION_OFFSET=0xA000 -DAPPLICATION_BINARY=debug.bin
failed to open source file: xyz.bin (ignoring for now)
APPLICATION_OFFSET = 40960
APPLICATION_BINARY = 0
error: line 20: error opening source 'APPLICATION_BINAR
my command_file.bd:
constants
   APPLICATION_OFFSET = 0;
sources
  APPLICATION_BINARY = "xyz.bin";
section (0)
   erase all;
   info "APPLICATION_OFFSET = $(APPLICATION_OFFSET)";
   info "APPLICATION_BINARY = $(APPLICATION_BINARY)";
   if (0 != APPLICATION_OFFSET)
      load APPLICATION_BINARY > APPLICATION_OFFSET;
      reset;
   else
      error "-DAPPLICATION_OFFSET=0x?????? must be supplied";
I want to have to "xyz.bin" replaced dynamically as it works great with the APPLICATION_OFFSET value.
