How to config MPU register
Question asked by 明超 戴 on Jul 4, 2016
Latest reply on Jul 12, 2016 by 明超 戴
Hi:
     I am using MPU mechanism in order to protect Pflash.The processor is MC9S12XEP100 and compile environment is Codewarrior. the global section which I want to protect is from 0x7FE000-0x7FFFFF,I want to set this section can not be written.my config as fellows:
void mpu_init(void) {
    unsigned long low_addr=0x7FE000;
    unsigned long high_addr=0x7FFFFF;
    MPUSEL=MPUSEL|0x01;
    MPUDESC0=0x40|(low_addr>>19);       //CPU in user state   low_addr:22-19
    MPUDESC1= (unsigned char)((low_addr&0x7FFFF)>>11);//low_addr:18-11
    MPUDESC2= (unsigned char)((low_addr&0x7FF)>>3);//low_addr:10-2
    MPUDESC3= 0x80|(high_addr>>19);//WP NEX  high_addr:22-19
    MPUDESC4= (unsigned char)((high_addr&0x7FFFF)>>11);//high_addr:18-11
    MPUDESC5= (unsigned char)((high_addr&0x7FF)>>3);//high_addr:10-2
    MPUSEL=0x80|MPUSEL;    //SVSEN=1,SEL=01;
after config  I found the MPU can not work . I need your help .I could not Understand why we need to config SEL.
could you give me some advise or demo .
                                                            thank you!
