Using the NFC PN532 bearkout board. I tried to connect through kitkat Android. The interface is I2C.
I am able to find the Linux driver I2C for the chip and built successfully.
https://github.com/NXPNFCLinux/nxp-pn5xx
To build android system, followed the guideline
http://www.nxp.com/documents/application_note/AN11690.pdf
Unable to follow the step in section 3.2.3.
May I get some guidance to include PN533 in Android system.
regards,
venkat
baytech systems, India
PN532 and PN533 are not supported under Android.
PN53x use an old proprietary protocol (called TAMA), which is not NCI compliant.
Please change to PN7150 if you want to use this Android code.
