I want to define and initialise a struct in flash at an absolute address.
The reason is that I need to see wether that struct is set by a download of the program into flash,
or it has been changed (by a flash-write) since it was downloaded before.
I know how to define a pointer to an absolute address.
I also found the following link:
https://mcuoneclipse.com/2012/11/01/defining-variables-at-absolute-addresses-with-gcc/
But I don't know how to use linker scripts.
Thanks in advance for the hepl.
Rens
