Hello, what does the u-boot config CONFIG_U_QE mean? I suppose CONFIG_QE is for Quick engine? but no idea about CONFIG_U_QE. Is there some documentation about these options? I didn't find it.
Many thanks
The T1042 QE block is the same as the T1040/ T1020/T1022 LS1021A/LS10 20A QE block. See the QUICC Engine Block Reference Manual:
The LS1021A Reference Manual names this QE block as "QUICC Engine (QE) lite block".
The u-boot uses CONFIG_U_QE and CONFIG_QE definitions for configuring of this block.
Pavel Chubakov
What processor do you use?
What version SDK do you use?
Pavel Chubakov
My processor is the QorIq T1042,
SDK version is SDK2.0
