Good morning,
I want to use a TJA1100 Broadr-Reach PHY in my application and I'm watching, as reference, the schematic of the TR1329 Customer Evaluation Board (that I found at the end of the document "TR1329 TJA1100 Customer Evaluation Board - User Guide").
Is there a document that explains how to select the filtering components at the MDI interface? Because I need to change the common mode choke with another one (for example the ACT45L-201-2P-TL000).
Thank you.
