imx6q sabresd board: SSI config problem
Question asked by Gary Yin on Jun 28, 2016
Latest reply on Jun 28, 2016 by igorpadykov
According to the schematics, the sound card WM8962 is connected to I2S-3 as the picture indicates.
But in the device tree file "imx6qdl-sabresd.dtsi", the related device node is :
sound {
      compatible = "fsl,imx6q-sabresd-wm8962",
                           "fsl,imx-audio-wm8962";
     model = "wm8962-audio";
     cpu-dai = <&ssi2>;
     audio-codec = <&codec>;
In the "imx6qdl.dtsi", 3 device node: "ssi1", "ssi2", "ssi3" are defined.
Why the device node above doesn't use <&ssi3> ? Is there a "logic device name" and "physical device name" mapping table?
