how to add more chip selects in T1040RDB_init_core.tcl file
gouravjain
Hi all,
Want to add more chip selects in T1040RDB_initcore.tcl file(original). so what i did, performed some free space testing on working chip select
# LAW1 to IFC (CPLD) - 128K
mem [CCSR_ADDR 0xc10] = 0x00000000
mem [CCSR_ADDR 0xc14] = 0xFFDF0000
mem [CCSR_ADDR 0xc18] = 0x81F00010
by changing just  mem [CCSR_ADDR 0xc14] = 0xA0000000 and
# CSPR
        mem [CCSR_ADDR [expr {0x124010 + $Altera_CS * 0x0C}]] = 0xA0000085
but its not working. pls tell me what else places i need to modify ??
regards,
Gourav
ufedor
You also need to add a MMU TLB for the 0xA0000000 in the "# MMU initialization" section.
gouravjain
hi,
modified as per your suggestion but still im getting "0x0000" from Hardware Diagnostic console...
Reading from target...
Read 0x0000 at address: 0xA0000000
Task Execution finished. Disconnecting ...
Below is the modified tcl file. pls let me know if im missing something.
# Initialization file for T1040 RDB board
# Clock Configuration:
#      CPU0: 1200/1400MHz, CCB: 600MHz,
#      DDR: 800MHz (1600 MT/s data rate) (Asynchronous), IFC: 150MHz,
#      FMAN1: 600MHz, QMAN: 300MHz, PME: 300MHz
# Choose which core will initialize the board
variable master_core 0
variable ECC_EN 1
variable CCSRBAR 0xFE000000
proc CCSR_ADDR {reg_off} {
  global CCSRBAR
  return i:0x[format %x [expr {$CCSRBAR + $reg_off}]]
proc init_board {} {
  # disable Boot Space Translation
  mem [CCSR_ADDR 0x28] = 0x00000000
  # Local Access Windows Setup
  # LAW0 to IFC (NOR) - 128M
  mem [CCSR_ADDR 0xc00] = 0x00000000
  mem [CCSR_ADDR 0xc04] = 0xE8000000
  mem [CCSR_ADDR 0xc08] = 0x81F0001A
  # LAW1 to IFC (Altera) - 128K
  # LAW2 to DCSR - 4M
  mem [CCSR_ADDR 0xc20] = 0x00000000
  mem [CCSR_ADDR 0xc24] = 0xF0000000
  mem [CCSR_ADDR 0xc28] = 0x81D00015
  # LAW3 to IFC (NAND) - 64K
  mem [CCSR_ADDR 0xc30] = 0x00000000
  mem [CCSR_ADDR 0xc34] = 0xFF800000
  mem [CCSR_ADDR 0xc38] = 0x81F0000F
  # LAW4 to Raycom0 - 64k
        mem [CCSR_ADDR 0xc40] = 0x00000000
        mem [CCSR_ADDR 0xc44] = 0xa0000000
        mem [CCSR_ADDR 0xc48] = 0x81F0000F
  # LAW5 to Raycom1 - 64k
        mem [CCSR_ADDR 0xc50] = 0x00000000
        mem [CCSR_ADDR 0xc54] = 0xb0000000
        mem [CCSR_ADDR 0xc58] = 0x81F0000F
  # LAW6 to XRT0 - 64k
        mem [CCSR_ADDR 0xc60] = 0x00000000
        mem [CCSR_ADDR 0xc64] = 0xc0000000
        mem [CCSR_ADDR 0xc68] = 0x81F0000F
  # LAW15 to DDR (Memory Complex 1) - 2G
  mem [CCSR_ADDR 0xcf0] = 0x00000000
  mem [CCSR_ADDR 0xcf4] = 0x00000000
  mem [CCSR_ADDR 0xcf8] = 0x8100001E
  # DDR Controller Setup
  # Get DDR type: 0 - DDR4; 1 - DDR3
  # set DCFG_CCSR_PORSR2 [mem [CCSR_ADDR 0xE0004]]
  # set DDR_TYPE [expr ($DCFG_CCSR_PORSR2 & 0x20000000) >> 29]
        # DDR_SDRAM_CFG
  mem [CCSR_ADDR 0x8110] = 0x47040000
  # DDR_CS0_BNDS
  mem [CCSR_ADDR 0x8000] = 0x7F
  # DDR_CS1_BNDS
  mem [CCSR_ADDR 0x8008] = 0x00000000
  # DDR_CS0_CONFIG
  mem [CCSR_ADDR 0x8080] = 0x80044302
  # DDR_CS1_CONFIG
  mem [CCSR_ADDR 0x8084] = 0x00000000
  # DDR_CS0_CONFIG_2
  mem [CCSR_ADDR 0x80c0] = 0x00000000
  # DDR_CS1_CONFIG_2
  mem [CCSR_ADDR 0x80c4] = 0x00000000
  # DDR_TIMING_CFG_3
  mem [CCSR_ADDR 0x8100] = 0x00060000
  # DDR_TIMING_CFG_0
  mem [CCSR_ADDR 0x8104] = 0x4011000c
  # DDR_TIMING_CFG_1
  mem [CCSR_ADDR 0x8108] = 0x6e6a0644
  # DDR_TIMING_CFG_2
  mem [CCSR_ADDR 0x810C] = 0x002880d0
  # DDR_SDRAM_CFG_2
  mem [CCSR_ADDR 0x8114] = 0x00401900
  # DDR_SDRAM_MODE
  mem [CCSR_ADDR 0x8118] = 0x00441420
  # DDR_SDRAM_MODE_2
  mem [CCSR_ADDR 0x811C] = 0x00800000
  # DDR_SDRAM_MODE_3
  mem [CCSR_ADDR 0x8200] = 0x00001420
  # DDR_SDRAM_MODE_4
  mem [CCSR_ADDR 0x8204] = 0x00800000
  # DDR_SDRAM_MODE_5
  mem [CCSR_ADDR 0x8208] = 0x000
  # DDR_SDRAM_MODE_6
  mem [CCSR_ADDR 0x820C] = 0x00000000
  # DDR_SDRAM_MODE_7
  mem [CCSR_ADDR 0x8210] = 0x00000
  # DDR_SDRAM_MODE_8
  mem [CCSR_ADDR 0x8214] = 0x00000000
  # DDR_SDRAM_MD_CNTL
  mem [CCSR_ADDR 0x8120] = 0x00000000
  # DDR_SDRAM_INTERVAL
  mem [CCSR_ADDR 0x8124] = 0x06180100
  # DDR_DATA_INIT
  mem [CCSR_ADDR 0x8128] = 0xdeadbeef
  # DDR_SDRAM_CLK_CNTL
  mem [CCSR_ADDR 0x8130] = 0x02000000
  # DDR_INIT_ADDR
  mem [CCSR_ADDR 0x8148] = 0x00000000
  # DDR_INIT_EXT_ADDRESS
  mem [CCSR_ADDR 0x814C] = 0x00000000
  # DDR_TIMING_CFG_4
  mem [CCSR_ADDR 0x8160] = 0x00000001
  # DDR_TIMING_CFG_5
  mem [CCSR_ADDR 0x8164] = 0x02401400
  # DDR_ZQ_CNTL
  mem [CCSR_ADDR 0x8170] = 0x89080600
  # DDR_WRLVL_CNTL
  mem [CCSR_ADDR 0x8174] = 0xc675f606
  # DDR_SR_CNTR
  mem [CCSR_ADDR 0x817c] = 0x00000000
  # DDR_WRLVL_CNTL_2
  mem [CCSR_ADDR 0x8190] = 0x07080809
  # DDR_WRLVL_CNTL_3
  mem [CCSR_ADDR 0x8194] = 0x090A0A00
  # DDR_DDRCDR_1
  mem [CCSR_ADDR 0x8b28] = 0x80040000
  # DDR_DDRCDR_2
  mem [CCSR_ADDR 0x8b2c] = 0x00000001
  # DDR_ERR_DISABLE - DISABLE
  mem [CCSR_ADDR 0x8e44] = 0x00000000
  # DDR_ERR_SBE
  mem [CCSR_ADDR 0x8e58] = 0x00000000
  # delay before enable
  wait 500
  # DDR_SDRAM_CFG
  mem [CCSR_ADDR 0x8110] = 0xc7040000
  # wait for DRAM data initialization
  wait 1500
  # eSPI Setup
  # SPMODE
  mem [CCSR_ADDR 0x110000] = 0x80000403
  # SPIM - catch all events
  mem [CCSR_ADDR 0x110008] = 0x00000000
  # SPMODE0
  mem [CCSR_ADDR 0x110020] = 0x2E170008
  # IFC Controller Setup
  global ECC_EN
  set ECC_ENC_EN  0x[format %x [expr $ECC_EN << 31]]
  set ECC_DEC_EN  0x[format %x [expr $ECC_EN << 26]]
  set NOR_CS 0
  set NAND_CS 1
  set Altera_CS 2
  set Raycom0_CS 3
  set Raycom1_CS 4
  set xrt0_CS 5
  # Altera, addr 0xFFDF0000,  128K size,  16-bit, GPCM, Valid
        # CSPR_EXT
        mem [CCSR_ADDR [expr {0x12400C + $Altera_CS * 0x0C}]] = 0x00000000
        # CSPR
       mem [CCSR_ADDR [expr {0x124010 + $Altera_CS * 0x0C}]] = 0xA0000105
        mem [CCSR_ADDR [expr {0x1240A0 + $Altera_CS * 0x0C}]] = 0xFFFE0000
        # CSOR
        mem [CCSR_ADDR [expr {0x124130 + $Altera_CS * 0x0C}]] = 0x00000000
        # IFC_FTIM0
        mem [CCSR_ADDR [expr {0x1241C0 + $Altera_CS * 0x30}]] = 0xE00E000E
        # IFC_FTIM1
        mem [CCSR_ADDR [expr {0x1241C4 + $Altera_CS * 0x30}]] = 0x0E001F00
        # IFC_FTIM2
        mem [CCSR_ADDR [expr {0x1241C8 + $Altera_CS * 0x30}]] = 0x0E00001F
        # IFC_FTIM3
        mem [CCSR_ADDR [expr {0x1241CC + $Altera_CS * 0x30}]] = 0x00000000
  # NOR Flash, addr 0xE8000000, 128M size, 16-bit NOR
  # CSPR_EXT
  mem [CCSR_ADDR [expr {0x12400C + $NOR_CS * 0x0C}]] = 0x00000000
  # CSPR
  mem [CCSR_ADDR [expr {0x124010 + $NOR_CS * 0x0C}]] = 0xE8000101
  # AMASK
  mem [CCSR_ADDR [expr {0x1240A0 + $NOR_CS * 0x0C}]] = 0xF8000000
  # CSOR
  mem [CCSR_ADDR [expr {0x124130 + $NOR_CS * 0x0C}]] = 0x0000000C
  # IFC_FTIM0
  mem [CCSR_ADDR [expr {0x1241C0 + $NOR_CS * 0x30}]] = 0x40050005
  # IFC_FTIM1
  mem [CCSR_ADDR [expr {0x1241C4 + $NOR_CS * 0x30}]] = 0x35001A13
  # IFC_FTIM2
  mem [CCSR_ADDR [expr {0x1241C8 + $NOR_CS * 0x30}]] = 0x0410381C
  # IFC_FTIM3
  mem [CCSR_ADDR [expr {0x1241CC + $NOR_CS * 0x30}]] = 0x00000000
  # NAND Flash, addr 0xFF800000, 64K size, 8-bit NAND
  # CSPR_EXT
  mem [CCSR_ADDR [expr {0x12400C + $NAND_CS * 0x0C}]] = 0x00000000
  # CSPR
  mem [CCSR_ADDR [expr {0x124010 + $NAND_CS * 0x0C}]] = 0xFF800083
  # AMASK
  mem [CCSR_ADDR [expr {0x1240A0 + $NAND_CS * 0x0C}]] = 0xFFFF0000
  # CSOR
  mem [CCSR_ADDR [expr {0x124130 + $NAND_CS * 0x0C}]] = 0x[format %x [expr 0x0110A100 | $ECC_ENC_EN | $ECC_DEC_EN]]
  # IFC_FTIM0
  mem [CCSR_ADDR [expr {0x1241C0 + $NAND_CS * 0x30}]] = 0x0E18070A
  # IFC_FTIM1
  mem [CCSR_ADDR [expr {0x1241C4 + $NAND_CS * 0x30}]] = 0x32390E18
  # IFC_FTIM2
  mem [CCSR_ADDR [expr {0x1241C8 + $NAND_CS * 0x30}]] = 0x01E0501E
  # IFC_FTIM3
  mem [CCSR_ADDR [expr {0x1241CC + $NAND_CS * 0x30}]] = 0x00000000
    # Raycom 0, addr 0xA0000000, 64K size, 8-bit device.
  # CSPR_EXT
        mem [CCSR_ADDR [expr {0x12400C + $Raycom0_CS * 0x0C}]] = 0x00000000
        # CSPR
        mem [CCSR_ADDR [expr {0x124010 + $Raycom0_CS * 0x0C}]] = 0xA0000085
        #AMASK
        mem [CCSR_ADDR [expr {0x1240A0 + $Raycom0_CS * 0x0C}]] = 0xFFFF0000
        # CSOR
        mem [CCSR_ADDR [expr {0x124130 + $Raycom0_CS * 0x0C}]] = 0x00000000
        # IFC_FTIM0
        mem [CCSR_ADDR [expr {0x1241C0 + $Raycom0_CS * 0x30}]] = 0xE00E000E
        # IFC_FTIM1
        mem [CCSR_ADDR [expr {0x1241C4 + $Raycom0_CS * 0x30}]] = 0x0E001F00
        # IFC_FTIM2
        mem [CCSR_ADDR [expr {0x1241C8 + $Raycom0_CS * 0x30}]] = 0x0E00001F
        # IFC_FTIM3
        mem [CCSR_ADDR [expr {0x1241CC + $Raycom0_CS * 0x30}]] = 0x00000000
    # Raycom 1, addr 0xB0000000, 64K size, 8-bit device.
  # CSPR_EXT
        mem [CCSR_ADDR [expr {0x12400C + $Raycom1_CS * 0x0C}]] = 0x00000000
        # CSPR
        mem [CCSR_ADDR [expr {0x124010 + $Raycom1_CS * 0x0C}]] = 0xB0000085
        mem [CCSR_ADDR [expr {0x1240A0 + $Raycom1_CS * 0x0C}]] = 0xFFFF0000
        # CSOR
        mem [CCSR_ADDR [expr {0x124130 + $Raycom1_CS * 0x0C}]] = 0x00000000
        # IFC_FTIM0
        mem [CCSR_ADDR [expr {0x1241C0 + $Raycom1_CS * 0x30}]] = 0xE00E000E
        # IFC_FTIM1
        mem [CCSR_ADDR [expr {0x1241C4 + $Raycom1_CS * 0x30}]] = 0x0E001F00
        # IFC_FTIM2
        mem [CCSR_ADDR [expr {0x1241C8 + $Raycom1_CS * 0x30}]] = 0x0E00001F
        # IFC_FTIM3
        mem [CCSR_ADDR [expr {0x1241CC + $Raycom1_CS * 0x30}]] = 0x00000000
    # XRT0 , addr 0xC0000000, 64K size, 8-bit device.
  # CSPR_EXT
        mem [CCSR_ADDR [expr {0x12400C + $xrt0_CS * 0x0C}]] = 0x00000000
        # CSPR
        mem [CCSR_ADDR [expr {0x124010 + $xrt0_CS * 0x0C}]] = 0xC0000085
        mem [CCSR_ADDR [expr {0x1240A0 + $xrt0_CS * 0x0C}]] = 0xFFFF0000
        # CSOR
        mem [CCSR_ADDR [expr {0x124130 + $xrt0_CS * 0x0C}]] = 0x00000000
        # IFC_FTIM0
        mem [CCSR_ADDR [expr {0x1241C0 + $xrt0_CS * 0x30}]] = 0xE00E000E
        # IFC_FTIM1
        mem [CCSR_ADDR [expr {0x1241C4 + $xrt0_CS * 0x30}]] = 0x0E001F00
        # IFC_FTIM2
        mem [CCSR_ADDR [expr {0x1241C8 + $xrt0_CS * 0x30}]] = 0x0E00001F
        # IFC_FTIM3
        mem [CCSR_ADDR [expr {0x1241CC + $xrt0_CS * 0x30}]] = 0x00000000
proc T1040RDB_init_core {} {
  global master_core
  variable CAM_GROUP "regPPCTLB1/"
  variable SPR_GROUP "e5500 Special Purpose Registers/"
  variable GPR_GROUP "General Purpose Registers/"
  # Memory Map
  #  0x00000000  0x7FFFFFFF  DDR        2G
  #  0xE8000000 0xEFFFFFFF  NOR  128M
  #  0xF0000000 0xF03FFFFF  DCSR      4M
  #  0xFE000000  0xFEFFFFFF  CCSR Space 16M
  #  0xFF800000  0xFF80FFFF  NAND      64K
  #  0xFFDF0000  0xFFE0FFFF  CPLD      128K
  #  0xFFFFF000  0xFFFFFFFF  Boot Page  4K
  # define 16M  TLB entry 1 : 0xFE000000 - 0xFEFFFFFF for CCSR_ADDR cache inhibited, guarded
  reg ${CAM_GROUP}L2MMU_CAM1  = 0x7000000A1C08000000000000FE00000000000000FE000001
  # define 256M TLB entry 2 : 0xE8000000 - 0xEFFFFFFF for NOR cache inhibited, guarded
  reg ${CAM_GROUP}L2MMU_CAM2  = 0x9000000A1C08000000000000E000000000000000E0000001
  # define 1G TLB entry 3 : 0x00000000 - 0x3FFFFFFF for DDR cache inhibited
  reg ${CAM_GROUP}L2MMU_CAM3  = 0xA00000081C08000000000000000000000000000000000001
  # define 1G TLB entry 4 : 0x40000000 - 0x7FFFFFFF for DDR cache inhibited
  reg ${CAM_GROUP}L2MMU_CAM4  = 0xA00000081C08000000000000400000000000000040000001
  # define 4MB TLB entry 5 : 0xF0000000 - 0xF03FFFFF for DCSR cache inhibited, guarded
  reg ${CAM_GROUP}L2MMU_CAM5 = 0x6000000A1C08000000000000F000000000000000F0000001
  # define 256K TLB entry 6 : 0xFFDF0000 - 0xFFE0FFFF for CPLD cache inhibited, guarded
  reg ${CAM_GROUP}L2MMU_CAM6 = 0x4000000A1C08000000000000A000000000000000A0000001
  # define 64K TLB entry 7 : 0xFF800000 - 0xFF80FFFF for NAND cache inhibited, guarded
  reg ${CAM_GROUP}L2MMU_CAM7 = 0x3000000A1C08000000000000FF80000000000000FF800001
  # init board, only when the init is run for master core
  variable proc_id [expr {[reg ${SPR_GROUP}PIR %d -np] >> 5 }]
  if {$proc_id == $master_core} {
  init_board
  # Interrupt vectors initialization
  # interrupt vectors in RAM at 0x[expr {${proc_id} << 1}]0000000
  # IVPR (default reset value)
  reg ${SPR_GROUP}IVPR = 0x[expr {${proc_id} << 1}]0000000
  # interrupt vector offset registers
  # IVOR0 - critical input
  reg ${SPR_GROUP}IVOR0 = 0x00000100
  # IVOR1 - machine check
  reg ${SPR_GROUP}IVOR1 = 0x00000200
  # IVOR2 - data storage
  reg ${SPR_GROUP}IVOR2 = 0x00000300
  # IVOR3 - instruction storage
  reg ${SPR_GROUP}IVOR3 = 0x00000400
  # IVOR4 - external input
  reg ${SPR_GROUP}IVOR4 = 0x00000500
  # IVOR5 - alignment
  reg ${SPR_GROUP}IVOR5 = 0x00000600
  # IVOR6 - program
  reg ${SPR_GROUP}IVOR6 = 0x00000700
  # IVOR7 - floating point unavailable
  reg ${SPR_GROUP}IVOR7 = 0x00000800
  # IVOR8 - system call
  reg ${SPR_GROUP}IVOR8 = 0x00000C00
  # IVOR10 - decrementer
  reg ${SPR_GROUP}IVOR10 = 0x00000900
  # IVOR11 - fixed-interval timer interrupt
  reg ${SPR_GROUP}IVOR11 = 0x00000F00
  # IVOR12 - watchdog timer interrupt
  reg ${SPR_GROUP}IVOR12 = 0x00000B00
  # IVOR13 - data TLB errror
  reg ${SPR_GROUP}IVOR13 = 0x00001100
  # IVOR14 - instruction TLB error
  reg ${SPR_GROUP}IVOR14 = 0x00001000
  # IVOR15 - debug
  reg ${SPR_GROUP}IVOR15 = 0x00001500
  # IVOR35 - performance monitor
  reg ${SPR_GROUP}IVOR35 = 0x00001900
    # Enable branch prediction
    reg ${SPR_GROUP}BUCSR = 0x01400201
  # Debugger settings
  # enable machine check
  reg ${SPR_GROUP}HID0 = 0x80000000
  # enable floating point
  reg ${SPR_GROUP}MSR = 0x00002000
  # infinite loop at program exception to prevent taking the exception again
  mem v:0x[expr {${proc_id} << 1}]0000700 = 0x48000000
  # prevent stack unwinding at entry_point/reset when stack pointer is not initialized
  reg ${GPR_GROUP}SP = 0x0000000F
  # DCFG_BRR - enable all cores
  mem [CCSR_ADDR 0xe00e4] = 0x0000000F
  # RCPM_CTBENR - enable all cores' timebase
  mem [CCSR_ADDR 0xe2084] = 0x0000000F
proc envsetup {} {
  # Environment Setup
  radix x
  config hexprefix 0x
  config MemIdentifier v
  config MemWidth 32
  config MemAccess 32
  config MemSwap off
# Main
  envsetup
  T1040RDB_init_core
ufedor
Sorry for the delay.
I believe that the TCL is correct.
There is one more configuration file which has to be changed - MEM - please see attached.
gouravjain
Now .tcl is working with your suggestion. After that i tried to make changes in u-boot also, but its got hanged.
Here are the changes made by me,
1) T104xRDB.h
#define CONFIG_SYS_RAYCOM1_BASE    0xFF900000
#define CONFIG_SYS_RAYCOM1_BASE_PHYS       (0xf00000000ull | CONFIG_SYS_RAYCOM1_BASE)
#define CONFIG_SYS_CSPR3_EXT    (0xf)
#define CONFIG_SYS_CSPR3        (CSPR_PHYS_ADDR(CONFIG_SYS_RAYCOM1_BASE_PHYS) \
                                | CSPR_PORT_SIZE_8 \
                                | CSPR_MSEL_GPCM \
                                | CSPR_V)
#define CONFIG_SYS_AMASK3       IFC_AMASK(64*1024)
#define CONFIG_SYS_CSOR3        0x0
/* RAYCOM1 Timing parameters for IFC CS2 */
#define CONFIG_SYS_CS3_FTIM0            (FTIM0_GPCM_TACSE(0x0e) | \
                                        FTIM0_GPCM_TEADC(0x0e) | \
                                        FTIM0_GPCM_TEAHC(0x0e))
#define CONFIG_SYS_CS3_FTIM1            (FTIM1_GPCM_TACO(0x0e) | \
                                        FTIM1_GPCM_TRAD(0x1f))
#define CONFIG_SYS_CS3_FTIM2            (FTIM2_GPCM_TCS(0x0e) | \
                                        FTIM2_GPCM_TCH(0x0) | \
                                        FTIM2_GPCM_TWP(0x1f))
#define CONFIG_SYS_CS3_FTIM3            0x0
2) tlb.c
#ifdef CONFIG_SYS_RAYCOM1_BASE
        SET_TLB_ENTRY(1, CONFIG_SYS_RAYCOM1_BASE, CONFIG_SYS_RAYCOM1_BASE_PHYS,
                      MAS3_SW|MAS3_SR, MAS2_I|MAS2_G,
                      0, 14, BOOKE_PAGESZ_256K, 1),
#endif
3) law.c
#ifdef CONFIG_SYS_RAYCOM1_BASE_PHYS
         SET_LAW(CONFIG_SYS_RAYCOM1_BASE_PHYS, LAW_SIZE_64K, LAW_TRGT_IF_IFC),
#endif
pls let me know where im doing wrong.
Gourav jain
ufedor
Please create new question concerning the U-Boot.
