I am running MQX 4.0.2 and using Codewarrior 10.6.4 to compile the code.
Now I am going to write a module using c++, so I wonder is it possible to make my setup support c++?
I wrote a cpp file, but it seems it can't compile this cpp file at all.
hi su,
what chip do you work with?
Jennie Zhang
I use K60FN1M0.
Hi su,
I use MQX4.2, I can find cplus demo code under
C:\Freescale\Freescale_MQX_4_2\mqx\examples\cplus\build\cw10gcc
Jennie Zhang
