I am dealing with some nasty problems with ALSA pcm and, what is seems, any type of DMA transaction. I would love to have some help from the community.
Before I continue with the problem I would like to describe my platform:
The ALSA pcm works just fine, I can write to the codec and the sound comes out just fine, but the problem is that when I do any DMA transaction eventually the ALSA pcm hangs. By any I mean serial communication (reading and writing to a terminal), USB requests allocation and freeing etc. If I increase the coherent_pool size to 1M, let say, it takes longer for the pcm to hang.
I already tested with newer kernel versions, such as 4.5 and 4.6 and it still hangs.
Considering I am setting up this device as a USB device using f_midi function (MIDI device). There are few ways I can easily reproduce here:
Example log of plugin the USB device to a host (I added those dma_pool_alloc/free prints):
[ 71.873046] wakeup int at ci_hdrc.1
[ 71.873068] ci_hdrc ci_hdrc.1: at ci_controller_resume
[ 71.877018] imx_usb 2184000.usb: at imx_controller_resume
[ 71.877035] wakeup int at ci_hdrc.0
[ 71.877056] ci_hdrc ci_hdrc.0: at ci_controller_resume
[ 72.244539] ci_hdrc ci_hdrc.0: dma_pool_alloc (ci_hw_td)
[ 72.249875] ci_hdrc ci_hdrc.0: pool_alloc_page (ci_hw_td)
[ 72.255384] ci_hdrc ci_hdrc.0: dma_pool_alloc (ci_hw_td)
[ 72.324438] ci_hdrc ci_hdrc.0: dma_pool_free (ci_hw_td)
[ 72.329696] ci_hdrc ci_hdrc.0: dma_pool_free (ci_hw_td)
[ 72.334958] ci_hdrc ci_hdrc.0: dma_pool_alloc (ci_hw_td)
[ 72.351103] ci_hdrc ci_hdrc.0: dma_pool_free (ci_hw_td)
[ 72.356374] ci_hdrc ci_hdrc.0: dma_pool_alloc (ci_hw_td)
[ 72.361751] ci_hdrc ci_hdrc.0: dma_pool_alloc (ci_hw_td)
[ 72.367171] ci_hdrc ci_hdrc.0: dma_pool_free (ci_hw_td)
[ 72.372427] ci_hdrc ci_hdrc.0: dma_pool_free (ci_hw_td)
[ 72.377692] ci_hdrc ci_hdrc.0: dma_pool_alloc (ci_hw_td)
[ 72.383071] ci_hdrc ci_hdrc.0: dma_pool_alloc (ci_hw_td)
[ 72.388543] ci_hdrc ci_hdrc.0: dma_pool_free (ci_hw_td)
[ 72.393799] ci_hdrc ci_hdrc.0: dma_pool_free (ci_hw_td)
[ 72.399063] ci_hdrc ci_hdrc.0: dma_pool_alloc (ci_hw_td)
[ 72.404450] ci_hdrc ci_hdrc.0: dma_pool_alloc (ci_hw_td)
[ 72.409922] ci_hdrc ci_hdrc.0: dma_pool_free (ci_hw_td)
[ 72.415176] ci_hdrc ci_hdrc.0: dma_pool_free (ci_hw_td)
[ 72.420440] ci_hdrc ci_hdrc.0: dma_pool_alloc (ci_hw_td)
[ 72.425824] ci_hdrc ci_hdrc.0: dma_pool_alloc (ci_hw_td)
[ 72.431295] ci_hdrc ci_hdrc.0: dma_pool_free (ci_hw_td)
[ 72.436548] ci_hdrc ci_hdrc.0: dma_pool_free (ci_hw_td)
[ 72.441810] ci_hdrc ci_hdrc.0: dma_pool_alloc (ci_hw_td)
[ 72.447189] ci_hdrc ci_hdrc.0: dma_pool_alloc (ci_hw_td)
[ 72.452562] ci_hdrc ci_hdrc.0: dma_pool_free (ci_hw_td)
[ 72.457816] ci_hdrc ci_hdrc.0: dma_pool_free (ci_hw_td)
[ 72.463076] ci_hdrc ci_hdrc.0: dma_pool_alloc (ci_hw_td)
[ 72.468449] ci_hdrc ci_hdrc.0: dma_pool_alloc (ci_hw_td)
[ 72.473923] ci_hdrc ci_hdrc.0: dma_pool_free (ci_hw_td)
[ 72.479177] ci_hdrc ci_hdrc.0: dma_pool_free (ci_hw_td)
[ 72.484439] ci_hdrc ci_hdrc.0: dma_pool_alloc (ci_hw_td)
[ 72.489833] ci_hdrc ci_hdrc.0: dma_pool_alloc (ci_hw_td)
[ 72.495767] ci_hdrc ci_hdrc.0: dma_pool_free (ci_hw_td)
[ 72.501021] ci_hdrc ci_hdrc.0: dma_pool_free (ci_hw_td)
[ 72.506274] MIDI Gadget gadget: high-speed config #1: MIDI Gadget
[ 72.512899] ci_hdrc ci_hdrc.0: dma_pool_alloc (ci_hw_td)
[ 72.593269] ci_hdrc ci_hdrc.0: dma_pool_alloc (ci_hw_td)
[ 72.598625] ci_hdrc ci_hdrc.0: dma_pool_alloc (ci_hw_td)
[ 72.603980] ci_hdrc ci_hdrc.0: dma_pool_alloc (ci_hw_td)
[ 72.609333] ci_hdrc ci_hdrc.0: dma_pool_alloc (ci_hw_td)
[ 72.614687] ci_hdrc ci_hdrc.0: dma_pool_alloc (ci_hw_td)
[ 72.620043] ci_hdrc ci_hdrc.0: dma_pool_alloc (ci_hw_td)
[ 72.625396] ci_hdrc ci_hdrc.0: dma_pool_alloc (ci_hw_td)
[ 72.630750] ci_hdrc ci_hdrc.0: dma_pool_alloc (ci_hw_td)
[ 72.636104] ci_hdrc ci_hdrc.0: dma_pool_alloc (ci_hw_td)
[ 72.641477] ci_hdrc ci_hdrc.0: dma_pool_alloc (ci_hw_td)
[ 72.646835] ci_hdrc ci_hdrc.0: dma_pool_alloc (ci_hw_td)
[ 72.652196] ci_hdrc ci_hdrc.0: dma_pool_alloc (ci_hw_td)
[ 72.657555] ci_hdrc ci_hdrc.0: dma_pool_alloc (ci_hw_td)
[ 72.662911] ci_hdrc ci_hdrc.0: dma_pool_alloc (ci_hw_td)
[ 72.668293] ci_hdrc ci_hdrc.0: dma_pool_alloc (ci_hw_td)
[ 72.673657] ci_hdrc ci_hdrc.0: dma_pool_alloc (ci_hw_td)
[ 72.679014] ci_hdrc ci_hdrc.0: dma_pool_alloc (ci_hw_td)
[ 72.684370] ci_hdrc ci_hdrc.0: dma_pool_alloc (ci_hw_td)
[ 72.689804] ci_hdrc ci_hdrc.0: dma_pool_free (ci_hw_td)
[ 72.695078] ci_hdrc ci_hdrc.0: dma_pool_alloc (ci_hw_td)
[ 72.700467] ci_hdrc ci_hdrc.0: dma_pool_alloc (ci_hw_td)
[ 72.705939] ci_hdrc ci_hdrc.0: dma_pool_free (ci_hw_td)
[ 72.711195] ci_hdrc ci_hdrc.0: dma_pool_free (ci_hw_td)
[ 72.716457] ci_hdrc ci_hdrc.0: dma_pool_alloc (ci_hw_td)
[ 72.721844] ci_hdrc ci_hdrc.0: dma_pool_alloc (ci_hw_td)
[ 72.727300] ci_hdrc ci_hdrc.0: dma_pool_free (ci_hw_td)
[ 72.732553] ci_hdrc ci_hdrc.0: dma_pool_free (ci_hw_td)
[ 72.737815] ci_hdrc ci_hdrc.0: dma_pool_alloc (ci_hw_td)
[ 72.743199] ci_hdrc ci_hdrc.0: dma_pool_alloc (ci_hw_td)
[ 72.748673] ci_hdrc ci_hdrc.0: dma_pool_free (ci_hw_td)
[ 72.753925] ci_hdrc ci_hdrc.0: dma_pool_free (ci_hw_td)
[ 72.759188] ci_hdrc ci_hdrc.0: dma_pool_alloc (ci_hw_td)
[ 72.764571] ci_hdrc ci_hdrc.0: dma_pool_alloc (ci_hw_td)
[ 74.051858] ci_hdrc ci_hdrc.1: at ci_runtime_suspend
[ 74.051922] imx_usb 2184200.usb: at imx_controller_suspend
[ 84.241825] playback write error (DMA or IRQ trouble?).
Thanks in advance.
Felipe Tonello
Hi Felipe
one can try more mature rex sw to check if this is caused
by hardware (ddr) errors
also one can post this on rex community
FEDEVEL Community Forum for Electronic Enthusiastics & Professionals - FEDEVEL Forums
What do you mean by more mature rex software? imx6rex-linux-3.10.17 or openrex-linux-3.14?
sorry, "mature" mean more well tested.
