S32DS for Power V1.1 Windows : offline licensing issue
Pat
Hi all,
I have to install the license offline. I get the activation.xml from my account -> licensing offline activation, and unfortunately during the installation in the java popup, the following message appears:"Invalid offline response, Response Type".
Is it a known issue ?
Pat
Tags (2)
stanish
Hi Pat,
Sorry about the delay and inconveniences caused by the activation issues.
Could you possibly try to check if the online activation method works on your side?
Thanks!
Stan
stanish
Hi Patrice,
We have just published hot fix that should fix the offline activation problem.
Could you possibly check this document: S32 Design Studio Offline activation issue hot fix
Hope it helps!
Stan
stanish
Hi Pat,
Thanks a lot for your notification.
We are currently experiencing some problems with activation code generation. (so the problem is not on your side)
Our licensing team is working on a fix.
I'll send out the official release announcement as soon as the problem is resolved (assume system is up and running in a day or so).
Thank you for your patience!
Stan
