Kinetis SDK Project Generator v2 - Windows 10 Support?
Deejay
I wonder if this is supported on Windows10 platform as I get the following error message:
"This app can't run on your PC. To find a version for your PC, check with the software publisher."
Any idea or work-around solution to run on Windows 10??
Thanks.
DJ
ZhangJennie
officially KSDK generator v2 doesn't support win10.
This product has been tested on the following system configurations:
this information is documented in KSDK Project Generator Release Notes - 2.1.pdf under Kinetis SDK Project Generator v2 folder.
Jennie Zhang
