License file
License file
evanlim
I'm using MobileGT V9.2 software with CodeWarrior USB TAP (cwh-ctp-base-he) on a window XP laptop.
I'm able to perform flash programming and hardware diagnostic testing when using the original license file.
However, after I use the license file that I had generated for that window XP laptop, I'm unable to perform both flash and hardware testing.
May I know what's wrong with the license file that I had generated?
Thanks!
Evan
TICS_Fiona
Hello Evan
For the license issue, I would suggest submitting a case. It's better under case process for private license details. For how to submit a case, please refer to:
https://community.freescale.com/docs/DOC-330215
Best Regards
Fiona Kuang
TIC - Technical Information Center
evanlim
Hi Fiona,
I had already submitted the case twice since end of June and I have yet to receive any reply from NXP.
I need the license file urgently as the 30days license file had already expired.
Thanks.
