qtmultimedia on framebuffer device
vincentchou
Hi!
We continue having problems to port our QT applications to the sabresd board because it always comes to issues when we try to playback video on frame buffer device.  Could you kindly tell me which version of fsl-release-bsp better support video playback using qtmultimedia and integrating gstreamer on frame buffer devices?  3.14.52 or 3.14.28? Qt4-embedded or qt5?
Vincent
vincentchou
We also discovered the network card would function normally if we switched back to version 3.0.35.  It will connect to Gigabit switch without problems.
Vincent
vincentchou
Sorry!  the last one is wrong posting!
Vincent
Bio_TICFSL
Hi Vincent,
You may try to test the latest release 4.1.15 and Qt5.
https://www.nxp.com/webapp/Download?colCode=L4.1.15_1.1.0_LINUX_DOCS&location=null&fpsp=1&WT_TYPE=Su...
vincentchou
Hi!
We start to try 4.1.15.  We also have our own qt application.  In order to build our own qt application which includes video playback feature, could you provide some information about how we could customize the local.conf to build core-image-base for our own qt application?
Vincent
Bio_TICFSL
Please check the meta-qt5 as reference for your image build.
GitHub - meta-qt5/meta-qt5: QT5 layer for openembedded
Hope it helps
vincentchou
Thanks!  I have already figured out by following the content of local.conf based on the other page for Qt application.
Compiling Qt5.3.0-beta1 on Yocto
I  could make it work now.  Thanks a lot for your help!
