V7.0 - IDE.EXE No Disk
tim35ca
When compiling or invoking the Flash Programming tools under CodeWarrior for Coldfire V7.0 we get multiple popup windows with this error:
IDE.exe - No Disk
There is no disk in the drive. Please insert a disk into drive D:
The tools are installed from the original installation CD 770-20334 Rev I.
Nouchi
Senior Contributor II
I've got the same problem few days ago, and mysteriously disappeared when I went back to CW6.4.
But I don't know if the problem was caused when I played with xml files configuration, or when I installed CW4.7.
I suspect a configuration problem in some case.
Emmanuel,
JRBurke
I'm getting the same problem today. Hasn't happened to me before and I'm using the same install of CW 7.0.
Any idas what this could be?
tim35ca
This is the second time I've run into this problem. The first time it was on one of my machines and the problem went away after I reverted to CW6.4. The second time it happened on one of my customers machines. He has reinstalled CW7.0 but still has the problem. I don't have access to his machine so I haven't been able to resolve it yet.
It was recommended that I open a service request with an explanation of the issue and also forward a copy of the Help > About Freescale Codewarrior > Installed Products. Since it is no longer happening on my machine could you enter the service request and let me know what they find?
Cheers!
