Hi when debugging using keil IDE and watching the TAD information while opening Debug->OS support->MQX-> I/O
DEVICES list, some device drivers show "UNKNOWN" " state, moreover, the init.handle has the same addresses
is it a normal behaviour ? or is there some mismatch between the drivers and the KEIL IDE ?
thanks
Hi Nissim
Could you please tell us your keil version, MQX version, and attach your console output here?
