USB dongle with CodeWarrior
ikkishingu
When I want to use USB dongle(CWH-DONGLE) for code warrior licensing,
1. which product should I get?
- Floating License
- Node-lock License
2. LMTOOLS using is required?
My customer would like not to use LMTOOLS
because it seems LMTOOLS doesn't work well on my customer's PC.
I would appreciate it if you could tell me how to use USB dongle without LMTOOLS, if possible.
Ikki
Tags (2)
TICS_Fiona
Hello  Ikki
A dongle-based license is a special type of node-locked license, in which the license is locked to the FlexID of a USB licensing dongle. So please choose Node-lock License if you want to use USB dongle.
LMTOOLS is only used for verifying whether the host can read the dongle ID. It can be downloaded from:
USB Dongle Drivers|NXP
For how to install dongle license, please refer to:
http://cache.nxp.com/files/soft_dev_tools/doc/support_info/DongleQS.pdf
Best Regards
Fiona Kuang
TIC - Technical Information Center
Note: If this post answers your question, please click the Mark Correct button. Thank you!
TICS_Fiona
Hello  Ikki
Best Regards
Fiona Kuang
ikkishingu
Hello Fiona
Thank you for your responce!
I understand that it is OK to get code warrior node-lock license & USB dongle for dongle activation.
LMTOOLS must be necessary?
Do you know the way to use USB dongle without LMTOOLS?
Ikki
TICS_Fiona
Hello  Ikki
LMTOOLS is used for checking whether the USB dongle driver is installed successfully, and for getting the dongle ID. It is not necessary for running CodeWarrior with dongle license.
Best Regards
Fiona Kuang
ikkishingu
Hello Fiona,
Thank you for your information!!
I can understand when LMTOOLS is required.
I think my customer's issue would be depending on their PC environment,
then for a start I will obtain USB dongle and try the activation procedure on my PC environment.
Ikki
