Where can I find specifications on the DMA maximum rate for the KL26 sub familiy
alejandra25
I am trying to find out the maximum DMA rate for the  KL26 sub familiy (in particular for  the MKL26Z128).
I see that for other devices there is a section in the chapter of eDMA in the reference manual that specifies it. Here is an example on the K60 Sub-Family Reference Manual:
Where can i find this specifications for the  KL26 sub familiy microcontroller runnig at 480MHz ? The reference manual does not seem to have a -Performance- section.
Thank you very much.
Hui_Ma
I will check with Kinetis team about related DMA module performance data.
Thank you for the patience.
Wish it helps.
Ma Hui
