MFG Tool is not detecting / ADB also not detecting via USB
bruno07eee
Hi All,
In detail  about the issue : (Platform - iMx6 sabresd)
1 . USB is working for Host/Mass storage (Mouse/Pendrive) But it is not working as a device
2 . PC is not detecting the board via USB(Even device manager, PC not able to recognize the usb)
3 . Hardware lines are proper which verified by probing the USB_ID line.
4 . Board is booting properly with last flashed images.
Please let us know how we can recover from this issue(Boot from emmc only is available)
Bruno(bruno@zumisolutions.com)
bruno07eee
Hi Igor,
Thanks for your quick response.
yes we have verified USB_ID is high and _VBUS line is powered(3.3volts)
Can you please suggest me that how i can proceed to rule out this issue.
Bruno
Hi Bruno
could you try connection with windows xp computer.
What is full processor marking, what mfg tools
version was used (link) ?
bruno07eee
Hi Igor,
I was using windows 7 and (We have around 6 development board)It is working with all the board except one board.
Is that fine for your question/ Still you need the mfg tool and environment details?
Note : Issue board was working fine and Issue occured after N number of reflashing the image via mfg tool
Please let me know if you need any details.
Bruno
Hi Bruno
if this just one board then this may be soldering issue,
one can resolder processor.
bruno07eee
Hi Igor,
Thanks for your update and Let me check with my hardware team for the same.
Hope i will update the root cause and the issue fixed notes here.
Bruno
Hi Bruno
please check with oscilloscope that USB_ID is high and
USB_H1_VBUS or USB_OTG_VBUS are powered.
Recommended to look at i.MX6 System Development User’s Guide for usb items
http://cache.freescale.com/files/32bit/doc/user_guide/IMX6DQ6SDLHDG.pdf
