Flashing the user application - KW40/41
sensenthuran
I am testing KW41 EVB.
I would like to flash an application (say, hci_app.bin) through UART connection.  I tried with blhost immediately after resetting the KW41W but  no response.
I am using the default boot loader that came with.  Do we need to have any special boot loader?
C:\FSL_Kinetis_Bootloader_1_2_0\FSL_Kinetis_Bootloader_1_2_0\bin\win>blhost.exe –d -p COM7,115200 -- get-property 1
[5a a6]
Error: Initial ping failure: No response received for ping command.
sensenthuran
Thanks, I ll check with them.
mario_castaneda
I am assuming that you are a alpha customer, this information is not available.
Could you please contact your FAE or Sales Representative for more information.
Best Regards
Mario
