MGSTAT0 occasionally set on flash erase
petersteinberg
I'm using a K20 (MK20DX128VLK7) processor.
Occasionally when I try to erase a block of the program flash I get an FTFL_FSTAT result with the MGSTAT0 bit set.
The block of flash still seems to have been erased properly.
It's very simple code:
FTFL_FCCOB0 = 0x09;
FTFL_FCCOB1 = (addr >> 16) & 0xff;
FTFL_FCCOB1 = (addr >> 8) & 0xff;
FTFL_FCCOB1 = (addr) & 0xff;
FTFL_FSTAT |= FTFL_FSTAT_CCIF_MASK;
while (!(FTFL_FSTAT & FTFL_FSTAT_CCIF_MASK)) ;
Any ideas on how to avoid this error or detect what is causing it?
  Peter Steinberg
johnreid
Was looking at MGSTAT0 as well and found it referenced in an errata for KINETIS: http://cache.freescale.com/files/microcontrollers/doc/errata/KINETIS_2N03G.pdf
This could be your issue.
petersteinberg
Disabling interrupts around the flash writes had no effect.
CCandido
Contributor V
Hi, test it,
                   __DI();
                       i =    flash_erase_sector( 0x10000 );
                       __EI();
unsigned int flash_erase_sector(unsigned int destination) // Sector = 4k
unsigned int returnCode=0;
if(FTFL_FSTAT&0b01000000){FTFL_FSTAT&=0b01000000;}
       if(FTFL_FSTAT&0b00100000){FTFL_FSTAT&=0b00100000;}
       if(FTFL_FSTAT&0b00010000){FTFL_FSTAT&=0b00010000;}
      FTFL_FCCOB0 = 0x09;
     FTFL_FCCOB1 = (unsigned char)(destination >> 16);
     FTFL_FCCOB2 = (unsigned char)((destination >> 8) & 0xFF);
     FTFL_FCCOB3 = (unsigned char)(destination & 0xFF);
     FTFL_FSTAT = 0x80;     // launch command
     if(FTFL_FSTAT&0x30){
         return(0xff);
     while(!(FTFL_FSTAT&(1<<7))){}
     returnCode = FTFL_FSTAT&0b01110001;
         return(returnCode);
