Speed scale parameters in AN4813 based on MC56F82748
kbk
How did you get angularSpeedScale=0.6357829 and angularSpeedScaleShift=4 in the application example code of document  AN4813?
xiangjun_rong
Regarding your question, the angularSpeedScale/angularSpeedScaleShift are just parameter, as you know that the motor speed unit is RPM(revolutions per minute), but you just divide the edge number by tick number, so there must be a scale, the scale is related to bus clock cycle time the TMR1 counts, the total edge numbers per revolution.
I attach an1931 whiuch is written by the same author, it describes how to calculate the scale k.
Hope it can help you.
XiangJun Rong
kbk
Got it, thank you very much.
