I'm just trying to compare microcontrollers right now, and putting together a spreadsheet comparing MPC574XG vs. SPC58NE84E7, S6J3350, ATSAMV70N19 as I'm interested in microcontrollers with at least two (2) CAN-FD peripherals. It appears that MPC574XG is a very powerful contender, but has no SCI ports?
MPC574xG in general supports SCI (namely UART). It is implemented in form of the serial communication interface called LIN or LINFlex.
Bernhard
yes, this is correct. LINFlex module supports LIN mode and UART (SCI) mode:
Simple SW example can be found here:
Example MPC5748G PinToggleStationery GHS614
Lukas
