Content originally posted in LPCWare by bobi-one on Mon Feb 07 15:05:14 MST 2011
I have 2Gb micro sd card which is loaded with some text and img files who I need to read with the lpcxpresso(lpc1343).
Which is the "easiest" way to do that with all the libraries that exist, without formatting the sd card in some special way. I've tried to compile some codes for the mbed but with no luck .It was too complex for me. If someone can share code for the lpcxpresso, I will greatly appreciate it :)
Thanks.
