Content originally posted in LPCWare by ronkrem on Sun Dec 22 06:01:04 MST 2013 I can find the stack top from the memory map, but how do I find the address of the bottom of the available stack area in an LPCXpresso program? I need these addresses to implement a stack usage monitor within my program. Regards
Content originally posted in LPCWare by ronkrem on Sun Jan 05 06:15:42 MST 2014 After some more map file searching I can now setup the stack for background monitoring. Here is the setup code:
