Content originally posted in LPCWare by deBoogle on Tue Feb 15 01:07:39 MST 2011
Hi All,
Firstly, I was going to mention the RIT in peripherals view but Skysat has got there first.
Secondly,
I must be missing something really obvious, but every time I try to write something to the RIT registers I generate a hard-fault, and end up in the hard-fault handler.
I should point out that I have an LPCXpresso board with an LPC1769 on board. Not that I think this will make much difference as it should follow the format for other LPC17xx devices.
I have forward declared the handler, and the code for this at the same time.
Then when I debug and step through, the first instruction to do anything with the RIT registers jumps me to the Hard Fault handler.
Any of you got any ideas? Thanks guys.
