Content originally posted in LPCWare by ehughes on Sat Feb 12 08:19:20 MST 2011
In the example code for msc_rom there are 2 callbacks for msc_read and msc_write.
It gives an offset and a length. MSC usb devices are supposed to have standard 512 byte read and writes but I notice that a value of 64 gets passed in alot as the write length.
Is this length parameter constant? If not how is it calculated in the rom functions?
