Workspace naming
Workspace naming
lpcware
Content originally posted in LPCWare by capstone on Thu Jun 12 11:49:37 MST 2014
Win 7-64/LPCXpresso v7.2.0
Workspace considerations
Is there a way to locate or visually see the current Workspace name?
- when more than one IDE launched, the Switch Workspace provides a list of previous selections, but may not have this
current selection as the first item.
Since the Workspace is a Logical assignment, how can the current Physical location be discovered?
How can the Name assigned to the Workspace be changed?
lpcware
Content originally posted in LPCWare by capstone on Thu Jun 12 16:59:18 MST 2014
Thanks! This was so simple; now the Workspace name is available.  ;-)
lpcware
Content originally posted in LPCWare by lpcxpresso-support on Thu Jun 12 13:52:55 MST 2014
The information in this article equally applies to LPCXpresso:
http://mcuoneclipse.com/2012/08/01/show-workspace-location-in-the-title-bar/
You just need to replace references to eclipse.ini with lpcxpresso.ini.
LPCXpresso Support
