static void accept_thread(void *socket) { int32_t sock = *((int32_t *)socket); uint_fast8_t exit_flag = 1; while(exit_flag) { char temp[20] = {0}; sprintf(temp, "s %d h %d s %d\n", sock, xPortGetFreeHeapSize(), uxTaskGetStackHighWaterMark(NULL)); lwip_send(sock, temp, strlen(temp), 0); uint8_t inbyte = 0; int32_t recvret = lwip_recv(sock, &inbyte, sizeof(inbyte), 0); if(recvret > 0u) { const char * const welcome = "hello\n"; lwip_send(sock, welcome, strlen(welcome), 0); } else { exit_flag = 0; } } lwip_close(sock); vTaskDelete(NULL); } void server_main(void *parameters) { int32_t socket = lwip_socket(AF_INET, SOCK_STREAM, 0); int32_t client_socket; struct sockaddr_in local_addr, client_addr; size_t client_addr_size = sizeof(client_addr); TSPRINTF("Server started\n"); if(socket >= 0) { memset((void *)&local_addr, 0, sizeof(local_addr)); local_addr.sin_family = AF_INET; local_addr.sin_len = sizeof(local_addr); local_addr.sin_addr.s_addr = htonl(INADDR_ANY); local_addr.sin_port = ntohs(((uint16_t)6666)); if(lwip_bind(socket, (struct sockaddr *)&local_addr, sizeof(local_addr)) < 0 ) { lwip_close(socket); TSPRINTF("Cannot bind port\n"); vTaskDelete(NULL); } if(lwip_listen(socket, 20) != 0 ) { lwip_close(socket); TSPRINTF("Cannot listen port\n"); vTaskDelete(NULL); } uint16_t counter_conns = 0; while(1) { memset((void *)&client_addr, 0, sizeof(client_addr)); client_socket = 0; client_socket = lwip_accept(socket, (struct sockaddr *)&client_addr, &client_addr_size); if(client_socket > 0u) { int32_t temp_socket = client_socket; if(xTaskCreate(accept_thread, "accept thread", 128 , (void *)&temp_socket, 2, NULL) == pdPASS) { TSPRINTF("Created %d connection\n", ++counter_conns); } else { TSPRINTF("Cannot create connection\n"); } } } } TSPRINTF("Destroy server task\n"); vTaskDelete(NULL); } |
