Ni: LPCXpresso RedlinkMulti Driver v8.1 (Mar 11 2016 13:34:34 - crt_emu_cm_redlink.exe build 672) Pc: ( 0) Reading remote configuration Nc: Found chip XML file in D:/Melo/Tachosafe 4/FW LPC/Bootloader/Release/LPC1756.xml Pc: ( 5) Remote configuration complete Nc: Probe Firmware: LPC-Link Probe v1.3 (NXP - LPC-Link) Nc: Serial Number: HID64HS12 Nc: VID:PID: 1FC9:0007 Nc: USB Path: Pc: ( 30) Emulator Connected Pc: ( 40) Debug Halt Pc: ( 50) CPU ID Nc: Emu(0): Connected&Reset. DpID: 2BA01477. CpuID: 410FC230. Info: <None> Nc: Debug protocol: SWD. RTCK: Disabled. Vector catch: Disabled. Nc: inspected v.2 On-chip Flash Memory C:\nxp\LPCXpresso_8.1.4_606\lpcxpresso\bin\Flash\LPC175x_6x_256.cfx Nc: image 'LPC175x_6x (256K) Feb 16 2016 09:18:54' Nc: NXP: LPC1756 Part ID: 0x00000000 Pc: ( 65) Chip Setup Complete Nt: Connected: was_reset=false. was_stopped=true Cr:v LPCXpresso Free License - Download limit is 256K Pc: ( 70) License Check Complete Ed:04: Failed to erase flash: Em(12). System rejected access at location 0xFFFFFFFF - verify Population of memory and peripherals Pc: (100) Target Connection Failed |
Ni: LPCXpresso RedlinkMulti Driver v8.1 (Mar 11 2016 13:34:34 - crt_emu_cm_redlink.exe build 672) Pc: ( 0) Reading remote configuration Nc: Found chip XML file in D:/Melo/Tachosafe 4/FW LPC/Bootloader/Release/LPC1756.xml Pc: ( 5) Remote configuration complete Ed:02: Failed on connect: Ee(36). Could not connect to core. Et:31: No connection to emulator device Pc: (100) Target Connection Failed |
