Content originally posted in LPCWare by Muis on Fri Oct 04 08:32:58 MST 2013
In all low-power examples unused pins are set to output and low. Is this the recommended configuration and is the consumption significantly lower than leaving those pins as inputs (with no pull up/pulldown)?
