Write failed: ProbeList Write failed: ProbeList Write failed: ProbeList at com.crt.debugcommon.emulator.client.RedlinkServerClient.writeln(RedlinkServerClient.java:1152) at com.crt.debugcommon.emulator.client.RedlinkServerClient.send(RedlinkServerClient.java:921) at com.crt.debugcommon.emulator.client.RedlinkServerClient.sendReceive(RedlinkServerClient.java:966) at com.crt.debugcommon.emulator.client.RedlinkServerClient.sendReceive(RedlinkServerClient.java:948) at com.crt.debugcommon.emulator.client.RedlinkServerClient.sendReceive(RedlinkServerClient.java:937) at com.crt.debugcommon.emulator.client.RedlinkServerClient.probeList(RedlinkServerClient.java:853) at com.crt.debugcommon.emulator.common.redlinkserver.RedlinkServerEmuHandler.discoverEmulators(RedlinkServerEmuHandler.java:208) at com.crt.debugcommon.emulator.win.AbstractWinServerProbe.discoverEmulators(AbstractWinServerProbe.java:77) at com.crt.debugcommon.emulator.EmulatorsDB.getEmus(EmulatorsDB.java:335) at com.crt.debugcommon.emulator.EmulatorsDB.getEmulatorInfo(EmulatorsDB.java:290) at com.crt.debugcommon.emulator.EmulatorsDB.getAvailableEmulators(EmulatorsDB.java:213) at com.crt.debugcommon.emulator.TargetDiscovery.probeDiscovery(TargetDiscovery.java:563) at com.crt.debugcommon.emulator.TargetDiscovery.probeDiscovery(TargetDiscovery.java:527) at com.crt.debugcommon.utils.LaunchScriptUtils.getEmulatorInfo(LaunchScriptUtils.java:306) at com.crt.debugcommon.utils.LaunchScriptUtils.init(LaunchScriptUtils.java:523) at com.crt.debugcommon.utils.LaunchScriptUtils.<init>(LaunchScriptUtils.java:214) at com.crt.debugcommon.utils.LaunchScriptUtils.<init>(LaunchScriptUtils.java:198) at com.crt.dsfdebug.dsf.services.TargetDiscoveryService.getTargetDiscovery(TargetDiscoveryService.java:146) at com.crt.dsfdebug.dsf.override.CRTFinalLaunchSequence$TargetDiscoveryJob.runInUIThread(CRTFinalLaunchSequence.java:102) at org.eclipse.ui.progress.UIJob$1.run(UIJob.java:97) at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35) at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:136) at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4147) at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3764) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1151) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332) at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1032) at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:148) at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:636) at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332) at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:579) at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150) at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:135) at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134) at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380) at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) at java.lang.reflect.Method.invoke(Unknown Source) at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648) at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603) at org.eclipse.equinox.launcher.Main.run(Main.java:1465) |
[Connected on port 3025] redlink> [Closed] [Connected on port 3025] redlink> [Closed] [Connected on port 3025] redlink> [Closed] [Connected on port 3025] redlink>ProbeList [Closed] [Connected on port 3025] redlink> |
[Connected on port 3025] redlink> probelist [Connected on port 3025] |
Microsoft Windows XP [Verzia 5.1.2600] (C) Copyright 1985-2001 Microsoft Corp. C:\nxp\LPCXpresso_7.6.0_321\lpcxpresso\bin\Scripts>listusb VID: 0458 PID: 003A (HID-compliant mouse) VID: 0458 PID: 003A (USB Human Interface Device) VID: 1AB1 PID: 0E11 (USB Test and Measurement Device (IVI)) VID: C251 PID: 2722 (HID-compliant device) VID: C251 PID: 2722 (USB Human Interface Device) C:\nxp\LPCXpresso_7.6.0_321\lpcxpresso\bin\Scripts> |
VID: C251 PID: 2722 (HID-compliant device) VID: C251 PID: 2722 (USB Input Device) |
Microsoft Windows XP [Verzia 5.1.2600] (C) Copyright 1985-2001 Microsoft Corp. C:\Keil_v5\ARM\ULINK\Utilities>UL2_Configure.exe V0471PGE B1 ULINK2 Configure Utility V1.0 Disconnecting ULINK .......... Connecting ULINK Loader ........................................ Updating configuration ... Configuration updated! Disconnecting ULINK Loader .......... C:\Keil_v5\ARM\ULINK\Utilities> |
C:\nxp\LPCXpresso_7.6.0_321\lpcxpresso\bin>redlinkserv.exe -commandline redlink>probelist Index = 1 Manufacturer = Keil Software Description = Keil ULINK2 CMSIS-DAP VID = C251, PID=2722 Path = \\?\hid#vid_c251&pid_2722#6&9840905&0&0000#{4d1e55b2-f16f-11cf-88cb-00111 1000030} redlink>probeopenbyindex 1 Handle = 1 redlink>wireswdconnect 1 DpID = 2BA01477 redlink>cminitapdp 1 0 AP_ID = 0x24770011 redlink>cmhalt 1 0 redlink>cmregs 1 0 R0 : 00000000 R1 : 00B71B00 R2 : 00000001 R3 : 00000000 R4 : 00000000 R5 : 00000000 R6 : 00000009 R7 : 00000000 R8 : 00000000 R9 : 02000168 R10 : 00000000 R11 : 00000000 R12 : 00000000 SP : 02001000 LR : 02000001 PC : 02000000 PSR : 41000000 MSP : 02001000 PSP : 00000000 CFBP: 00000000 redlink>probestatus 1 Index = 1 Manufacturer = Keil Software Description = Keil ULINK2 CMSIS-DAP VID = C251, PID=2722 Path = \\?\hid#vid_c251&pid_2722#6&9840905&0&0000#{4d1e55b2-f16f-11cf-88cb-00111 1000030} IsOpen = TRUE WireInitialized = TRUE WireProtocol = SWD CoresConfigured = FALSE PacketSize = 64 Probe Reference Count = 0 HasSWV = FALSE HasETM = FALSE HasJTAG = FALSE HasSWD = TRUE Probe Type = CMSISDAP redlink>probeclosebyindex 1 redlink> |
"No compatible emulators available. They may be disconnected, not powered, already in use or not compatible with this target" |
redlink> |
redlink>pTokenizer error Error: Unexpected token 31 redlink> |
